Electrical heater around concrete crown
I am Talla, project engineerfrom France.
My project consist of adding a heating belt around my propane vessel concrete crown in order to have a positive temperature on it.
–>The vessel contains liquid propane at -42°C, so, the vessel steel internal temperature is -42°C (B.C 1)
–>The vessel is insulated and we assume that the external temperature is around 0°C (B.C2)
–>The vessel is layed above a concrete apron ,where the surface temperature is around 2°C because it is heated (B.C 4)
–>The heating belt temperature is to be difined , now, I assume it to 45°C (B.C3)
If the heating belt is good, the temperature in the internal concrete crown sould be around 5°C.
That is a two-dimensional heat transfer problem.
I do not knwo if the simulation is good because I do not have an analytical approach to compare with it.
Khowing that the insulation disk thickness is 200 mm and its thermal conductance is 0.037 W/m°c, we should not have at the final result a very low temperature.
Do you know what kind of heat transfer shall I do to compute the heating belt’s power to add?
I enclosed some screenings.
I intended to have a positive temperature in the internal face of the concrete crown, but I have around -14°C.
How to proceed ?
screenings
Project link
Hi Talla
This project is really interesting, and I like your approach. Let me ask you a question though, aren’t you interested in the heat transfer between the solid and the fluid? This requires a different analysis type, the Conjugate Heat Transfer, have a look at the following pages:
Let me know what you think about it :slight_smile:
Also, regarding this statement:
If the heating belt is good, the temperature in the internal concrete crown should be around 5°C.
How did you get to this conclusion, taking into consideration the boundary conditions you set?
Hi Fillia,
Thank you for your quick answer.
You suggest me to use a conjugate heat transfer to solve my problem. It would be fantastic, That was the first idea Iget but, I can’t handle it because there are some problems related to the seed faces and regions I can’t define.
Would you like to help me doing it.
I read the links you send me several times but I never arrive to succeed my simulation.
Best regards!
Talla
Check this project: https://www.simscale.com/workbench/?pid=2403172301928889348&mi=spec%3A53377203-f5ff-4de8-92d1-fe8e7c9481d9%2Cservice%3ASIMULATION%2Cstrategy%3A17
I created an Open Inner region that represents the liquid.
5 posts were split to a new topic: Multiple boundary conditions error
2 posts were split to a new topic: The specified maximum runtime of the job was exceeded error
Hi there,
I have made a good progress in my CFD simulation but, Istill have problems.
  • BC1 : I want to maintain all the liquid propane (flow region) at -42°C, it seems to be impossible.
    In this way, I can just fix a face temperature at -42°C.
    Does someone know how to proceed, please ?
  • *In the part Results, how to interpret the convergence plot Residuals, area average
Project link
Best regards !
Talla,
