I am trying to understand the use of porosity: Porosity & Porous Media | Advanced Concepts | SimScale .
I have used a leafed tree (from trees by rtir | SimScale), but in winter the leafs are gone and thus one could simulate this with porosity (and even in summer there will be some porosity).
There are several ways to implement porosity (as the porous-media link says). I have now tried it using ‘Perforated Plate’ as I found it simple to configure: Zwiepse Molen by vreijs | SimScale
So I gave the tree this ‘Perforated Plate’, but how does this ‘plate’ look like (its dimensions?)? Is this ‘plate’ a ‘flat’ object that traced the contours of my tree (in the direction of the defined flow)?
Or should I use a different way of porosity (but then how do I configure its parameters)?
Any help/hint/link is welcome. Thanks.
This deduction of mine is wrong!!! d should be zero, thus: dx=dy=dz=0
Checked the ‘transparency’ of my oak tree. With leaves (summer) it would be around 95% coverage with leaf/branches. Without leaves (winter) there looks to be some 20% of coverage with branches. So if 95% compares to a LAIsummer of 5.2, then LAIwinter is around 5.2/95*20=1.1…
And thus for winter fx=fy=fz=2 * Cd * LAIwinter/h = 0.44/h
But this is all guessing for me. So any help is wanted
