Hello I am designing a simulation to estimate the rate of heat transfer of a diver in still water conditions and I am getting these two errors popping up:
“Multiple boundary condition or interface assignments for the following entities: NONE@Boss-Extrude1, NONE@Boss-Extrude1, NONE@Boss-Extrude1, more …
Velocity must not be a zero vector for Velocity inlet 2.”
Here is a link to my project any help is appreciated!
Thank you for the reply, I have been able to rub the simulation a few times but can’t seem to record any wall heat flux other than the one that i induce as a power source, was wondering if I had something wrong in the setup. Body thermal loss | Other | SimScale
glad that I could help.
In regards to your setup issue can please describe me a bit further how you want the simulation to be setup and what boundary conditions are?
Also since you are only interested in the Wall Heat flux. Maybe a convective heat transfer analysis with an external wall heat flux might be possible.
Hello Sebastian, the two unknowns in my simulation that I am looking to investigate are the convective heat transfer coeffecient and thus overall heat transfer flux in the system, thus when I tried to use the convective heat transfer analysis I was unable to do so since it asks for a heat transfer coeffecient input.
The boundary conditions I am currently using are:
Natural Convection for inlet and outlet
With Regards,
Mohamad
