I am working on a model that doesn’t have face to select for a Velocity Inlet/Outlet.
Do I need to model this differently to take this into account before running a simulation on it?
Hi there, this is Fillia ![]()
In order to get the flow volume, you will have to create an open inner region.
An open inner region is defined by an enclosed space with a limited number of openings to the outside void. The extraction is performed by:
See the example of a flow silencer below:
This is how the flow region will appear after the extraction:
By default, the original geometry is removed when the fluid volume is extracted. It is possible to keep all original parts by enabling the ‘Keep Existing Parts’ toggle
This will result in a geometry that contains both the fluid volume as well as the outer wall geometry as two separate parts. However, for a simple fluid flow simulation, only the fluid volume is required. Keep the original geometry only in case of a Conjugate heat transfer simulation in which the transfer of heat between the solid parts and the fluid domain needs to be simulated.
To learn more about Flow Volume Extraction, have a look here: How to Create Flow Volume Extraction? | Knowledge Base | SimScale
Thanks for the assistance.
Also this helped a lot because the seed face concept isn’t exactly obvious to a novice.
Choosing the Seed Face In Flow Volume Extraction | SimScale
One other thing I had to do is shell my model outward so that I had enough surface area to select the boundary face (26ga sheetmetal makes for a very tiny face to select otherwise.
