Distributed Propulsion system
I am facing so much error in simulation. Please check my meshing and give appropriate sizing. Please check the rotating zone placement and direction of 2prop project. I want to find aerodynamic coefficients on the wing of this geometry.
Hi @vedantchaudhari thanks for posting on the forum and welcome to the SimScale Community :handshake:
You seem to have attached a link to your dashboard, could you provide a link to your project? Make sure to follow the guidelines here before posting:
If you’re new to SimScale and are facing many errors as you’ve mentioned, I’d strongly recommend that you run 2-3 introductory tutorials before going to your own model:
Project Link - 2 Propeller | SimScale Workbench
Not able to generate mesh on propeller blades. I want to do the meshing and reduce non orthogonal elements. I’ve tried giving fillet to every component possible. I have tried everything in the refinement control from volume, surface to inflation. coarse to fine also. But the elements are getting out of non-orthogonal range
Also, the propeller is not rotating in simulation.
Hi @vedantchaudhari,
You seem to have deleted the mesh/simulation you mentioned in the post - in this case I can’t tell where the problem is exactly. However, I can still make a few comments:
A final comment is regarding the transient nature of your study. Although it’s possible to run OpenFOAM transient studies, they need to be carefully calibrated taking the Courant number and the timestep into consideration. We have a must-watch webinar on this topic:
Project link is Distributed Propulsion | SimScale Workbench
I have provided RPM to MRF region. I am not sure whether the propeller rotated during simulation or not. How to check that? How the get video visualization of propeller rotating in transient simulation in post processing?
Hi @vedantchaudhari, I guess you’re looking for an AMI Rotating Zone instead of an MRF: Rotating Zones | Advanced Concepts | SimScale
Regarding the visualization, you should be able to see it if you were to create an animation filter in the post processor.
