i ad a doubt with respect to the y + mesh for kw sst model
what should i give for minimum thickness and final thickness
cause i dont the range of y+ mesh in turbulence mode of kw sst model?
so could please specify the minimum and max y+ value using kw sst
Hey there!
Please refer to this article for the answer to your question:
but im using hex dominant parametric , what is the range of y+?
Also the range for kw sst model?The article dosent mention this.
I gave the inital boundary layer as 1.8e-5, assuming y+<1
but i dont know what to give the final boundary layer as i dont know the range of y+ in kw sst model
So could you please tell me this
They y+ value is not related to the type of mesh used, but to the wall modelling:
