Trouble viewing surface stream lines
Hi there,
I’m having trouble viewing the outputs of my simulation. I am using the incompressible CFD software. All I can see is the enclosure, I can not see how my model actually behaves. How do I view the outputs without the enclosure? Perhaps I am doing something wrong with setting up my simulation.
I would really appreciate your help.
Kind regards,
Kegomoditswe (Struggling final year engineering student)
Can you share the project link with us here in the thread? :slight_smile: Will help you out then!
Here’s the link: https://www.simscale.com/workbench/?pid=8778348232929807834&mi=spec%3Aa8252900-33b1-4a3f-9a9d-de16d9559487%2Cservice%3ASIMULATION%2Cstrategy%3A7&ps=analysis%2FIncompressible--oneOf%2Fmaterials%2Ffluids%2F0
Thanks!
Kegomoditswe
Hi!
I had a look at your project and the boundary conditions look unusual to me. For instance, the velocity inlet is being applied in a direction tangent to the side wall:
Could you tell us a little more about this application? Maybe we can propose more fitting BCs afterward.
I’ll also post some links which will probably be useful:
Hi
I followed the tutorial and tried running the simulation again. However, I am running into the same problem. I changed the boundary conditions as suggested and followed the tutorial step by step.
Application: I am trying to determine the forces, bending moment, and stresses acting on the model in that at high speeds.
Here is the link to the new simulation: https://www.simscale.com/workbench/?pid=253181473203790855&mi=spec%3A5b8a6414-c4c1-4d13-b783-ffda7e1bcb96%2Cservice%3ASIMULATION%2Cstrategy%3A323
Thanks!
Kegomoditswe
