Hi ,
Need help with placing the Velocity Inlets and their Pressure Outlets will share the link . Please do Help me with the earliest Support
Hello @Nishaant_S , and thanks for posting your question in the Forum!
First, you will need a flow region generated inside the rooms and connections to define velocity inlet and pressure outlet conditions. At the moment, you have only the solids which can not be assigned as fluid boundary conditions.
Please have a look at the following tutorial page to see how an internal flow volume is generated inside a room, as well as this documentation page for more information.
Thanks!
Kaan
