I need help!! How i have to set it so I can see how my Wind Turbine Rotor in Wind.
To understand the workflow in setting up rotating zones you can take a look at these tutorials;
Drone Simulation Using Rotating Zones Tutorial
Water turbine Tutorial
Essentially the workflow is:
Create a wind tunnel domain around the rotor
Add a cylindrical rotating zone enclosing the blades
Define the rotation axis and angular velocity
Run the simulation, then use post-processing to display streamlines/velocity
Thanks!
Bryan
