I wish to simulate heat transfer and velocity profile for both inside the wrap around heat pipe (internal volume) and the air flowing on the outside of the heat pipe (external volume). Is this possible? If yes, how can i model and simulate this?
Hi there, this is Fillia
It seems you are asking for a Conjugate Heat Transfer analysis, have a look here:
Make sure to select the original version that allows for two different fluids to be modeled.
Check some tutorials here:
Best regards, Fillia
