Screw turbine
How to mesh properly for rotating blade …error I got was : A multi-region mesh was assigned - this analysis-type requires a single-region mesh.
When does this error occurs…
Do I have isolate shaft if yes how…
My project is to calculate power, efficiency, torque and angular velocity for give flow rate of water at certain height…
How to simulate canal with head 1 m.
Is this project possible using CFD…
If possible give tip to avoid Any mistakes in cad preparation and meshing…
Please take a look at Simscale documentation: Pump Curve: How to Assess Turbomachinery Performance with SimScale.
Retsam
Hi @mnoor_mohamed: I suggest you read following project description: Internal CFD with MRF.
Start by making very simple simulation domain first. You will be able to do complex shapes once mastering the basic rules.
Retsam
Thank you for the example. I tried and ran simulation.I tried to use simpler setup for by screw turbine shaft by enclosing it into region.And add 2 layers at inlet and outlet. I learned that inlet n outlet should be closed…so i add the layers…then the result was : Job was prepared successfully…The mesh generated result in image like this
… ALSO WITH AN ERROR : The continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions.
The initial geometry was https://a360.co/35aZC7u.
I want simulate a screw turbine with head 1m and angle of 18degree. Is it possible to include this as parameter in cad modeling part ???
If you want it to be rotating, enclose the geometry in another cylinder (not too close to the geometry and not too far away) which can then be used for a MRF zone.
Do i have create the enclosure using enclosure tool in the workbench or should i add enclosure in cad model itself :slight_smile:
Just do it in your CAD which you can parametrize anytime :wink:
i want add head and angular flow to this turbine…similar to the pic with few modifications https://www.youtube.com/watch?v=6jsBWvrIxCM
Just want to clarify if what i think is correct on how to preparing this cad model… constructing 2 rectangular tanks connected by pipeline with turbine shaft.
How generate graph for torque ??
Thank you very much for help.
Based on above diagram …i have constructed a cad model… https://a360.co/37r9XOb… But at mesh section
there is message like this …
The two rectangle act as tanks to provide head… which parts to solidfy and how to solidify the parts
IS MY MATERIAL SELECTION OF VOLUME CORRECT(i,e all the volume)
Or should i just select the turbine blade only or both blade n shaft ???
IS MRF ROTATING ZONE COMPULSORY FOR ALL ROTATING PARTS ??.if yes…1 doubt…should i select the faces of the blades only or both the shaft and blades of the screw turbine
Hi @mnoor_mohamed.
In your CAD program, you need to create 3 solids first:
  1. Simulation domain (where water would flow)
  2. Archimedes screw
  3. MRF cylinder which will contain your rotating screw.
But once ready, you have to remove (using Boolean operation) the Archimedes screw from your Simulation domain. You will be left with a hole in that first solid. That hole will have the shape of removed body.
Now you are left with that new solid and MRF zone (total 2 solides). You need to import them into SimScale.
All those steps are described in Internal CFD with MRF project. You should read it again and perhaps make a copy and play with it.
Most of your questions will be answered after above exercise. Please be back once you are ready for your simulation.
Retsam
Thank you very much @Retsam…I will do it :slight_smile: just to clarify I would have to place the screw inside the mrf cylinder and and mrf cylinder would be inside the simulation domain…1 more doubt ???
do I have to keep end of mrf cylinder closed or keep it open like (hollow cylinder)
MRF zone should contain a volume, so it will be a closed cylinder.
The simulation is in water, so what is necessary is that water volume only. Now, MRF allows to define rotation speed for that water.
In your free time I suggest also to read documentaion Pump Curve: How to Assess Turbomachinery Performance with SimScale, as you intend evaluate your setup once able to simulate it.
Hai @Retsam i created the cad model https://a360.co/2sLjEIp… then i made sure that the turbine shape is removed from flow region as such
then i upload into my workbench to ensure 2 solids as u mentioned … I tried meshing algorithm hexa -dominant parametric …it failed as shown … i tried hexa dominant parametric because it was used in the turbo machinery webinar…i not sure what algorithm to use and how to define mesh refinements…can you confirm cad model and help me accordingly …
thank you for all the support
:slight_smile:
Hi @mnoor_mohamed: You did not fail. That message is a standard one, just click on ‘Use Mesh as Domain’.
Parametric mesh is rather complex one. You can play with HEX automatic mesh first, which will do a refinement for you.
I suggest you provide a link to your public SimScale project, which would help to spot possible errors.
Retsam
Link : https://www.simscale.com/workbench/?pid=6906030336417307545&mi=spec%3Ae69fb355-2222-4667-9a1b-1bfe771bcea4%2Cservice%3ASIMULATION%2Cstrategy%3A20
ok…i will try :slight_smile:
I had support team ajitkumar help me with mesh refinements(mesh 5) …the mesh went well but simulation end in error ok multi mesh region being assigned …
Now, before running simulation, you need to go to Advanced Concepts > Rotating Zone > MRF and select your MRF volume…
Ok i do it and simulate :slightly_smiling_face:
Thank u…
Please now go to Result Control > Forces and moments and select geometry you have in your scope. You can also gather Surface data from your Pressure outlet.
And of course, observe the Convergence plot…
:smiley: SIMULATION IS SUCCESSFUL for the one without MRF zone which i started before i saw your message on adding it… i added the MRF Zone and simulated again … :slightly_smiling_face:
