Hi there, I am running a simulation for the F1 in Schools competition however everytime I try to run a simulation the mesh is produced with max Non-orthogonality ranging from 87-90 degrees which cannot be fixed without correctors. Which results in the simulation either failing or providing inaccurate results without visualisation of the fluid flow around the car with the particle trace tool is there anything I need to do or do I need to add any other boundary conditions in order to produce accurate results? Thanks.
This seems to come from the gap between the tires and the floor. See the solution in this cad for instance (creating an artificial “block” between the tires and the floor).
