im followowing an older tutorial and they used a refinements tab, i cant find it where it is in the video
Hi @kriperkriperic ,
Thanks for posting on the forum. Generally speaking, I’d recommend that you have a look at some of the newer tutorials based on the new UI. It should help to avoid confusion.
In any case, in the new UI you will need to create a simulation before having access to the mesh settings. Basically you need to select the geometry and create a simulation (selecting the analysis type of interest):
And then the mesh settings will be visible in the left-hand side panel, including refinements.
