hello I am a beginner in simscale, I want to simulate the flow in multiphase in spurs gears but I have difficulty in the boundary conditions, the 4 model region and the multiphase, can you help me to see the 2 phase flow only, thanksFlow simulation on the Spurs gear
Hi there, can you also include the link to your project please?
Hi there, thank you for sharing!
The model currently has some issues you should fix. For example, there are some gaps in the flow region, resulting in various parts, instead of a single continuous fluid domain, as you can see below:
So to begin with, the model should have be consisting of a single part - the flow region-, otherwise it will not be simulated.
When you fix the model, you can have a look at the following multiphase pages, and use them as reference:
