Correct boundary condition settings for a turbulent wall resolved mesh
Hello community,
i need some knowledge for a turbulent incompressible case.
turbulence modells:
  • kEpsilon
  • kOmega
Could any body write down the correct boundary condition for a turbulent wall resolved mesh.
patch wall:
  • U: noSlip
  • p: zeroGradient
  • k: zeroGradient or fixedValue 0 ?
  • omega?
  • epsilon?
  • nut = calculated?
Hi @e0625598!
Please refer to this post: Defining Turbulent Boundary Conditions
Also the names you states for the “wall patch” you have to make a difference between the patch and the actual wall boundary condition:
  • Patch: Generic type containing no geometric or topological information about the mesh (inlet, outlet, etc.)
  • Wall: Rigid Wall (patch that coincides with a solid wall \rightarrow using wall functions)
The names are identical on the platform. What case are you trying to simulate? Did you already have a look at the Public Project section to look for a template?
Hello @jousefm,
thanks you for your link, but i could not find the required information.
What setting the solver is using when Full resolution on wall boundary condition is selected.
what setting are set on the backend for:
  • U
  • p
  • k
  • nut
  • omega (if kOmegaSST turbulence model is used)
  • epsilon (if kEpsilon turbulence model is used)
Thank you in advance
Hi @e0625598!
This post might help you out about yplus and wall functions in general: What is y+ (yplus)?
  1. “Full boundary layer Resolution”
  • yPlus around 1 (in the viscous sublayer)
  • current setup: k = 0
  • omega = omegaWallFunction
  • nut = nutkWallFunction*
  1. “Wall function approach”
  • 30 < yPlus < 300 (in the logarithmic sublayer)
  • Current setup: k = kqRWallFunction
  • epsilon = epsilonWallFunction
Does that help? For further information I would need to delve a bit deeper into it and see what I can find out.
@e0625598 you can find the backend definitions by downloading the solved case file and reading the patch definitions for each variable in time 0.
Darren
