Conjugate Heat Transfer simulation fails with error
I am trying to simulate a shell and tube heat exchanger for a small cogeneration unit I am building from a 5kVA diesel genset. It’s just a personal project at the moment, and the heat exchanger is oversized on purpose. I just want to simulate it out of curiosity.
I have no previous experience with simulation software, so maybe I just made some stupid basic mistake.
I used this tutorial as a starting point and just changed some of the values: Conjugate Heat Transfer in U-Tube Heat Exchanger | SimScale
I had to increase the water flow rate a lot, because in the tutorial the 0.01kg/s comes out to just 36 L/h. The pump I am using is rated at 900 L/h and since I am obviously adding some resistance I put 400 L/h (0.11 kg/s) to be on the low side.
I left the flow rate of the gas as is for now, because I am not sure what the exhaust flow rate of the engine is and how to calculate it. I am sure its possible to get a rough estimate using the fuel consumption, cylinder displacement and RPMs, but I have to look into it some more. If someone here has a simple formula or can do the calculation quickly, I would be very thankful. The fuel consumption is 1.8 L at max load, displacement is 418cm³ and it’s running at 3000RPM.
Other than that I just changed some of the temperatures.
I am not sure if air is even the best material, because the exhaust gas is obviously not air. Is there a better alternative or is air close enough?
The error I am getting is:
Maximum number of iterations exceeded when calculating temperature from a thermodynamic potential. This may be caused by low-quality mesh producing unrealistic pressure in a few cells or inappropriate boundary conditions, fluid properties or time step. Inspect fields for large values in the last time step.
I already tried to increase the quality of the mesh and played around with some other settings, but I don’t really know what I’m doing.
Here is the link to the project: SimScale
Thanks for any help
Hi there, it seems that the issue is mesh-related, I suggest you try to visualize the results as a start, to investigate whether there are bad cells. A way to do this is by using isovolumes, as described here: How to Check and Improve Mesh Quality | SimScale
Let me know about your findings, and make sure to add an Imprint operation too.
A more detailed troubleshooting guide can be found here: Error: Maximum Number of Iterations Exceeded | SimScale
thank you for the answer.
I checked the links and tried to use the isovolumes filter, but I can’t get it to work. I am not really sure what it is, but I tried to set it up like it says but I cant even set the min and max values correctly because it only goes to 1 for me. I thought it might be a percentage, so I set it to 0.20 and 0.93 instead but I still don’t see anything like on the site:
It did read a bit further about mesh quality though. What I found out is that it might be bad that my CAD file (Fusion 360) consists of multiple bodies, because the meshing could create some voids between the parts. So I combined them all into one body in Fusion and because I read sharp corners are bad as well, I threw in some small fillets on all internal edges. In reality I will braze it together, so there will be filets too, so might not be a bad idea anyway in case it makes a difference for the water flow.
Then I re ran the mesh and tried the simulation, but still get the same error…
Any more ideas?
Hi Sebastian, try the isovolumes feature in the post-processing environment (Solution fields) that appears under the stopped run.
Hi Fillia,
I’m sorry for the stupid questions, but I don’t know what I have to set there and what I’m actually looking for. This is my first ever simulation project. Could you please give me some more details on how I can find the issue?
At a first glance, the issue with the failed simulation is the relaxation type under Numerics - I’d suggest trying “Automatic” here:
PS: it would be a good idea to use a coarser mesh. The current mesh has more than 30 million elements and it probably won’t run all the way until the end, given the community plan runtime limitations.
it was the Relaxation Type, now its working.
Thank you very much!
