Computing quota
am trying to run a simulation incompressible (lbm) in order to test aerodynamics of f1 in schools car, but an error pops up about computing quota. But i upgraded to an academic plan and I have 3000 CPU hrs remaining and this simulation is just around 20 CPU hrs. I don’t understand why it does not run the simulation. I tried to reduce the exporting domains mesh refinements and running time but still. Do you know any way that it will run the simulation?
Hi @krossos, thanks for posting on the forum
Pedestrian Wind Comfort, LBM and Multi-purpose analysis are only available to SimScale professional accounts:
Some users report only being able to run LBM/PWC studies. This happens because there is an import option for STL files called ‘Optimize for LBM / PWC.’ When selected, the CAD model is imported as a faceted geometry, which is specifically tailored for use in PWC/LBM simulations.
If this applies, you’d just need to toggle this option off.
