I have been trying to simulate a bluff body in SimScale, and I have consistently getting bad convergence. The residual - ‘p’ in particular is behaving weirdly.
I tried increasing the domain size, and it helped, but still I would like to understand the reason for this behavior.
You can compare: Fuselage 45m long enclosure simulation
Pressure Force Z is oscillating. And also Pressure Force X is slightly oscillating.
The residuals are also oscillating.
With: Fuselage 90m long enclosure → Hex Mod 0.06
The residuals are drastically showing better convergence
There is no oscillation in any of the forces.
Also, the option to select TET mesh is not available. Only three options are there - Standard, Hex, Hex Parametric.
I assumed you mean TET-dominant. If you mean Standard mesh, I can give it a try!
