Hi there,
I am new to the CFD and I have tried to run several tutorial projects but I need some assistance on the projects.
I tried the the " User Guide: External Aerodynamics around a vehicle" I could not find the “Material Point” Option. I could only find “Background Mesh Box”. Where can I find the Material point option?
There are the rule of thumb on mesh box size and several other numbers. How can I find out how each numbers came about? While waiting for Question 1, I am doing “Tutorial: Incompressible turbulent airflow around a front wing” and there are many more parameters that I would like to know how the numbers come about.
How do I do a multiple faces/ box select? in the front wing tutorial, I ended up using right click select all visible parts after hiding the non wanted faces. Is there a drag box or shift-click kind method?
When meshing and simulating, how do I get a preview of estimated time before starting and estimated remaining time? All I see is the percent completed and how long the simulation has been running.
Lastly and perhaps the most newbie question, how do I reverse the rotation direction of my mouse?
Thank you beforehand for your help!
