Yes. If you look at the centre of mass it is exactly coincident with the Y-axis (the direction in which gravity acts) in both the X and Z planes; and 4.7mm below the centreline in the Y-axis (as you’d expect given the frame is under the tank.)
Hi, just quickly stopping by - the model contains a number of interfering parts, between the rubber and the water tank. You should be able to spot those by running an “interference” check in CAD mode.
The idea was to have the model simulate the compression of the rubber parts to check that they would survive the weight and so protect the tank from the steel supports.
I don’t know how to simulat that yet.
I will remove the interfernce and see if that resolves the asymmetry.
