Hi, there.
I want to know why does it not showing the simulation result. (https://www.simscale.com/workbench/?pid=7651199325040052606&mi=run%3A15%2Csimulation%3A11&mt=SIMULATION_RUN)
Hi, there.
Hello, you are currently running a 1000 seconds transient LES simulation, which will definitely take a while to run (and also requires a very carefully crafted set up). Even then, this would take days and potentially weeks to run.
I’d strongly suggest starting out with a steady-state simulation, such as in this tutorial.
Hi Rick,
Thank you so much! I will modify it and run it again with steadystate setting! I will let you know if the result is great!
