What simulation should I use?
Hellow Simscale members,
I would like to know the temperature change of Die When I put some optic on the PCB.
I already know the environmental results. So, I want to make the simulation environment the same as it is.
Here is my experiment sequence.
(I only used Heat Transfer simulation)
  1. In fact, without panel(LC, Glass), The IC’s degree is 44 degrees. So I drew a model without panel.-done
  2. I found the power(volume heat flux) that makes the IC 44 degrees.-done
  3. In fact, when the IC and panel were combined and operated, the die temperature of the panel was 52 degrees.-done
  4. I found the power that makes the die 52degrees(also, IC power is as the same as 2))-done
  5. In face, when the IC and panel were combined and operated with an optical covered on top of it, the die temperature of the panel was 61 degrees - ing
For 5), I drew a model and simulated. But the temperature fell rather than rise.
Common sense, Since it’s covered, shouldn’t the temperature go up?
Am I wrong using Heat Transfer?
If there’s anything that confuses you, please let me know
Best Regards,
Jake
Hey Jake,
Could you please send me the URL of your project, so I can have a look at the setup?
Dear ggiraldof,
Here is my project URL
Thank you for you support
I think that your results can be attributed to the lack of modeling the air inside the cover, and the additional convection faces, which release energy that should be stored in the air.
You can add the air model using a Conjugate Heat Transfer simulation. You also need to create the part to assign the air, for this use the Create Flow Region operation inside the CAD Edit Mode:
Dear ggiraldof,
As you told me, I’m setting up simulations using “conjugate heat transfer”.
I also set inner flow in the optic volume. I think succeeded up to here.
But the problem is, I can’t understand about “boundary condition”.
Without “boundary condition” the temperature is saturated to room temperature.
I tried “natural convection inlet/outlet” just in case, but I’m confused about which to allocate it
I just want to set the natural condition.
In the boundary condition workbanch, What can I use for this project? and How can I use them?
I’ll put a rink below, so please refer to it.
Best Regards,
Jake
