I want to analyse the hull resistance of a ferry. Is the total resistance in x direction already included in pressure force x ? Or do I have to add viscous force and also add friction resistance ?
Hi @flodderich,
The total resistance in x is the sum of the pressure and the viscous components in the x-direction.
Thanks! BTW: Does SimScale consider the friction on the ships hull ?
So do i have to do a manual calculation on the friction of the hull regarding the roughness ?
In this case, you should consider explicitly defining the wall roughness in your simulation - I’ve written a short article some months ago, showing the workflow in SimScale.
