Iβm modelling the piston of a medical device compressing air inside a vented chamber and Iβve run into a puzzling result that Iβd appreciate your thoughts on:
Intial Volume = 846.000 ππ^3
Final Volume = 182.400 ππ^3
Atmospheric Pressure (Pressure Outlet) = 101.325 πππ
Compressed Pressure (Pressure Inlet) = 470.300 πππ
I have performed an incompressible fluid simulation with these parameters. The simulation reports a peak velocity magnitude of roughly 850 m *s^β1 (past supersonic), which strikes me as highly improbable.
Could this excessively high velocity magnitude be an artefact of using an incompressibleβflow model or is it more likely that something else in the setup is driving the error?
Thanks in advance for any guidance!
