Velocity diverging in finer meshes
Hello everyone,
I am trying to simulate the flow around an aerial vehicle but I am facing issues when using finer meshes.
When using coarse standard or hex meshes, the simulation is able to complete. When I try to use a finer mesh of either kind, the velocity diverges in the area around or above the top wing.
Searching online, someone suggested using a transient simulation instead but when running that, the pressure diverges instead.
Here is a link to the project: SimScale
Hope someone can help me understand what is happening here.
Thanks,
Rumesh
Hi Rumesh,
I suggest you try the mesh settings from this tutorial, with the Standard meshing algorithm: Incompressible Turbulent Flow Around a Spoiler | SimScale
Of course some of the refinement inputs have to be adapted to your model, but this should work well for your case. This is steady-state, no need for a transient analysis :slight_smile:
Hi Fillia,
Thanks for the suggestion, I created a mesh similar to that from the tutorial but that ended up being an extremely fine mesh, it took significantly longer to solve but atleat it did not fail this time.
However, the residuals are still similar to that by the original coarse mesh used. Do you have suggestions for decreasing the residuals?
Also, do you have possible explanations for why the divergence happens in the first place? I am trying to understand what is happening here so I can be prepared if it happens again in the future
Hi!
The model isn’t very clean, which can definitely cause issues with mesh quality (ultimately leading to divergence). From a quick inspection, I found some very small faces:
In any case, whenever you face a diverging simulation, I’d recommend going through the steps in this article.
In short, it’s usually either mesh quality (for which my usual recommendation is CAD clean-up) or wrong boundary conditions.
Hi!
Thanks for the note on small faces. The velocity does diverge close to a region of high volume ratio. I will look into cleaning up the CAD model.
Thanks for your help!
