I am trying to learn Simscale to a deeper level. I have completed several models using two phase flow (mostly the tutorial problems). Now I created a model of a problem that I have sorted out in the real world to see if I could model it and come up with the same answer.
Short version is: a diversion pipe, large diameter, transitions from horizontal to 15% slope. In the process it entrains air in a specific flow range. The air causes flow restrictions further down the pipeline. Question to be answered is how much air needs to be vented at air release valves?
Problem: I can’t get the model to run, always getting an error “signal 8 encountered”. I have tried checking things and making adjustments, but just can’t figure out the problem. Maybe it is just too large?
I could really use some input from someone with two phase flow experience.
Thanks in advance,
Stephan
