I have a problem with the core hours in this proyect. It consist in simulating a 3D model of a tree, the type of simulation is incompresible (LBM).
I made two diferent resolutions for the 3D model, the simulation execution time and mesh count didn´t change, in the following image i will exibit the trees
Img 1.High resolution tree
Img 2. Low resolution tree
I reduce all parameters that i can and the simulation didn´t become more lighter. What i can do in this case? The simulation set up is the following.
Img 3. High resolution tree setup
The distribution of the faces in the setup is explain in the image below.
