SimScale CAE Forum
Step-by-Step Tutorial: Homework of Session 1 - Level 2
NOTE: This tutorial was updated on 08/2016 to match the updated version of the platform
If you would like to watch the first session of the Drone Workshop again or in the case you missed it, you can access the full recording below.
You have just set up your [first simulation of the aerodynamics of a drone](https://www.simscale.com/forum/t/step-by-step-tutorial-homework-of-session-1-level-1/297) from the first session of our online Drone Workshop.Now we will start Level 2.
Level 2
Background:
Level 2 includes the CFD analysis of the modified ducted-fan geometry for the drone. This task requires you to firstly generate the mesh with a rotating zone and then setup a simulation with Multi-Reference-Frame (MRF) and advanced boundary conditions.
Step-by-Step instruction
Mesh
The CAD geometry is already provided in the Drone_HW-task-2 project, that can be imported here
  • Under the geometry tree, click on the geometry Drone_Ducted-Fan-STEP. From the geometry options panel, click on Mesh geometry. This will automatically create a Mesh operation and make the mesh operation selection panel active.
  • From the panel select > Hex-dominant parametric (only CDF). This type of meshing approach is necessary for the generation of a ‘rotating zone’ that is required for the analysis.
Important: The rotating zone is defined using an additional solid region included in the CAD geometry.
  • In the same panel under Bounding Box Discretization specify the following values for number of cells in each X,Y and Z directions for the BaseMeshBox as shown in figure below:
  • Number of cells in x direction: 40
  • Number of cells in y direction :65
  • Number of cells in z direction : 40
  • and under ‘Parallel Processing’, the number of processors as : 32.
At the top, click on Save.
After saving , sub-trees named Geometry Primitives and Mesh Refinements will automatically appear under the default ‘Operation 1’ tree.
Under Geometry Primitives, click on BaseMeshBox and specify the values as shown below and click on ‘save’
Next, click on material point and specify the following sample values:
Center (x) : 0.113
Center (y) : 0.0677
Center (z) : 0.1731
This will place the material point in the space between the Bounding BaseMeshBox and the geometry surfaces. So, this is the confined space that will be meshed.
Next, create 3 additional geometry primitives by clicking on Geometry Primitives and then New from the options panel and select type cylinder. These will be used to define Region Refinements later on.
  • Name the first as Cylinder-outer and specify the values shown in figure below and click ‘save’:
Similarly, for the other 2 geometry primitives of type cylinder specify the values given below:
Make sure you ‘save’ after each one.
Now, we will group the geometry solids under the Topological Entity Sets tree.
First click on the pick volumes icon in in the tool bar above visualization window. Then select the MRF-zone and click on “Create entity set from viewer selection” in the options panel.
Onces created, hide the volume by selecting it again and clicking hide selection from the tool bar (slashed eye icon) so that only the rest of the volumes are visible.
Do the same for the 3 other volume sets. Once all volume sets are created, click on the show all icon in the tool bar (right to the hide selection icon).
Duct: Solid_0
Arm-assembly: Solid_1
MRF-Zone: Solid_2
Blade-1: Solid_3
Blade-2: Solid_4
Next, from the visualization window selection tree, we will hide the Solid_0 till Solid_2 , by clicking off the eye symbols. Then, on the tool bar we click on icon pick faces, then click on selection and select all. This will select all visible faces of the rotor-blade. Lastly, click on Create entity set from viewer selection and name it blade-faces
Now, we add the necessary surface, region and layer refinements for the mesh.
Click on Mesh refinements in the tree and add new mesh refinement from the options panel. Then select and enter the values as shown in the figure below.
Care must be taken that here for the type surface refinement , the create cell zone must be set to True and the volume set MRF-Zone must be assigned.
For refinement of the surface mesh of Arm-assembly and duct we add a new surface refinement and assign the values as shown in figure below:
For refinement of blade surface mesh , we add another surface refinement as follows:
For refinement of the volume mesh region we add 3 region refinements of different refinement levels. So, click add refinements and add a region refinement as depicted below and save it.
Add 2 more region refinements with the specified values and save after each:
Lastly, we add body aligned cell layer to the rotor blade faces. So, create a new mesh refinement and select Layer addition with following values.
All the mesh refinements are now complete. We will now adjust some additional (advanced) settings to get a better quality mesh. So, make sure the corresponding values are as shown in the figures below:
Once done, click save and start the meshing process by clicking on the start button at top. The meshing process will take less than an hour to finish.
Simulation Setup
Switch to the Simulation Designer tab and select New Simulation. Enter preferred name and click create.
From analysis Type select the options as shown in the figure below and click ‘save’. After saving, a tree will automatically generate in the left panel window that will be completed step by step.
Next from the tree, click on Domain and select the mesh under Meshes and click Save as shown in figure below. After saving, the mesh will automatically load in the visualization window.
Now, we will create face sets under Topological Entity Sets that will be used to define boundary conditions later on.
Click on pick faces icon in tool bar [2] and select the highlighted faces [3] as shown in figure below. Change filter for entity types to face sets [4] and click on Create entity sets from viewer selection [5] to create the Symmetry-faces set.
Before creating the next set, we will hide the previous set Symmetry-faces by clicking on it [3] and clicking hide selection icon [4] to hide it.
Now, we select pick faces from tool bar [5] and select the highlighted side faces as shown in figure below [6] and click on Create entity sets from viewer selection [7] to create the sets called Side-faces.
Similarly, we follow the above steps to one by one create 2 new sets called Top-face and Bottom-face by selecting the corresponding faces shown in above figure.
Onces done, we one-by-one hide the four face sets as shown in figure below [2] . Next, we select pick faces from tool bar [3] and select the highlighted Duct faces as shown [4] to create another set.
Again, we hide set Duct-faces first and then select all rotor faces (30 in total) to create a set called Rotor-Blade as shown below.
lastly, hide all created sets [2] and click pick faces from tool bar [3]. Now we see only the Arm-assembly in the viewer as shown in figure below. Click on selection in tool bar and Select all [4] to select all visible faces at once. So, create the last set called Arm-assembly-faces by clicking on create set button [5].
Adding Materials
Now, we define the boundary conditions by clicking on the sub-tree named Boundary Conditions and clicking New from the options panel.
To define no-slip wall condition for the drone, enter and select the options as shown in figure below . Please note that you do NOT need to select from the viewer. Just assign by clicking the shown face set and click Save.
The second boundary condition is type symmetry and is setup as shown below. Again, just assign by clicking the shown face set and click Save (no selection from viewer required)
Similarly, we create a new Slip-wall condition for the Side/Bottom Faces as illustrated in figure below.
Lastly, we will make the top face an open boundary face that can act as a free flow inlet or outlet (at the same time) depending upon the flow inside the domain. To do third we choose type as Custom and set the values as shown in figure below:
Now to define the rotation zone, click on Advanced Concepts sub-tree entry and Add rotating zone by clicking on the button in options panel as shown below.
Select and assign the values as shown in the figure below to set the rotating MRF zone. Check RotatingZone under MRF Zone section for entity types volumes and click save
Under the Numerics sub-tree entry make the changes as shown in the figures below and save them.
Make the following changes to the values as shown in figure below.
Click on Result Control and click New and add Forces and Moments item from the options panel and enter the values as shown in figures below. (Again, No selection from viewer is required).
Finally, click on Simulation Runs, then on Create new run from the options panel as shown and start the run. Thats all … !
Congratulations, you have completed the Homework of Session 1 - Level 2 and can now move on to Session 2:
Homework of Session 2 - Level 1
Step-by-Step Tutorial: Homework of Session 1 - Level 1
Session 1: Aerodynamics in Drone Simulation
Good morning!
By starting the Mesh of the homework_level_2 I got these messages and the Mesh operation was cancelled:
“Illegal triangles were found after surface tesselation. There could be a problem with the CAD geometry. Trying to proceed anyway. The tesselated surface is not closed. There could be a problem with the CAD geometry (such as self-intersections). Please inspect your geometry. Trying to proceed anyway.”
I checked again the Mesh and everything looks ok. Can you please help me?
Thank you very much!
Hi again!
I tried again with the Mesh. I received the messages again but the Mesh operation was not cancelled. It worked now!
Have a nice day!
Dear Iria,
the message you received is only a ‘warning’ and does not means that meshing is impossible. Just ignore it :wink:
Milad
#5
Good day,
in trying out Tutorial 2, I reached this point where I’ve created the mesh geometry, but after entering the Simulation Designer, and creating a new Simulation, I am unable to select the mesh geometry that I had created.
under the Domain selection, in the middle panel, I can see the mesh geometry, but cannot select the radio button.
is this due to a problem in my mesh geometry?
Thank you.
#6
did you wait until the meshing job was finished? It would be helpful if you could post a screenshot.
Milad
#7
HI Milad,
Thanks for that!
You’re right, meshing wasn’t completed yet, hence it wasn’t selectable in the Simulation stage.
#8
Hey @Milad_Mafi :smile:
Just one question: Only one simulation for the Level 2 homework, right?
I am not sure if we need 8 simulations like in Level 1.
Thank you for your help my friend :smiley:
Hey Jousef,
yes that is right. Only one simulation for level two.
But everyone who run the same eight simulations for level 2 will receive props from me!
Milad
#10
Hi Milad,
thanks for this nice session.
Concerning exercice 2, I was just wondering which blade geometry is involved. Does it correspond to the “drone 1” of the first exercice?
Olivier.
#11
Good evening @olive ,
the level 2 geometry is blade 2 from the level 1 homework.
Good evening @jousefm,
interesting, I was expecting the ducted fan to improve the lift, but apparently it is the opposite effect (if it is actually the blade 2 geometry).
Any physical explanation for that?
Olive
#13
Hey @olive ,
I looked again and yes it is blade 2.
Physical explanation might be something like the following excerpt from a quadrocopter forum:
For the same diameter, fans are more efficient than props because they reduce tip losses at the prop. A 10" 2 blade fan will be more efficient then a 10" 2 blade prop. However since fans are mostly used inside of small jets, they need to be small, hence the poor efficiency compared to for instance a pusher prop. To get sufficient power from the small fan, more blades and high pitch were used, which also reduces efficiency, but gives high output velocity and thus more power.
In general, for generating thrust, moving lots of air with small speed (big prop, low pitch) is more efficient then moving small quantities of air with high speed (small prop, high pitch)
So if you take your quad and just put a shroud around the existing props, you should get better efficiency then before and it shouldn’t be harder to control. The weight gain of the shrouds might offset any efficiency gain though and you still may not get better flight times.
Very important for static thrust with fan (with a copter we want lots of static thrust from the fan) is to give it a nice rounded intake, just like you see on eg a Boeing 747 engine (witch is also a ducted fan btw, but driven by a turbine instead of an electric motor)
If you replace your existing big props with small fans, your efficiency will be very poor and control much harder.
Source: http://diydrones.com/forum/topics/quadcopter-arducopter-with
Does this make sense to you? If not, I will see what I can find out :grin:
Good night and happy simulating,
Good Afternoon Everyone,
Nice to see you in this discussion forum for Home work Level-2.
Regarding the geometry for this task, the blade angle is the same as Level-1 , Blade design-2. But, there are some minor difference in blade thickness. This geometry for Level-2 has a slightly thicker blade that is exactly 0.5 mm uniformly thick ( i.e from top to bottom surface) with a filleted leading edge and a flat trailing edge. In comparison the level-1, design-2 blade had both sharp leading and trailing edges.
Well, Should you come across any issues or problems with this homework, please feel free to post them here.
I hope that you all stay tuned.
Cheers and happy simulating :slight_smile:
Ali
#15
About kinematic viscosity used in the model. It looks like we are using the default value 0.000001 m2/s. The kinematic viscosity of air seems to be about 0.00001 m2/s (see, for example, http://www.efunda.com/materials/common_matl/show_gas.cfm?MatlName=Air0C). Did I miss something obvious? Thank you!
#16
Hi Milad,
The homework is really interesting, just a small question; why do we need to add layers in the rotor blade faces if we already made a mesh refinement on it? how this layers helps us to improve the simulation? thank you very much for your answers
David
#17
Hey @ragemandav ,
I guess the layers are useful to define that just the surface has a fine mesh because thats where the air streams (it is therefore legitimate to have a “coarse” mesh inside the blade). So I guess the surface is more important than the inner part of the blade. Reminds me in some ways of the Boundary-Element-Method where you do the same. Just Mesh the surface (for instance crankshafts etc…) and you will get a pretty accurate result (sometimes even better than in FEM but depends on the case).
Just an idea, maybe @Milad_Mafi has a better explanation for us :smile:
@ragemandav @jousefm I would say it’s because of wall function not surface mapping :wink:
#19
Hey @ragemandav @jousefm
we are using layers elements to resolve the exponential velocity gradient of the boundary layer:
Milad
#20
Hi Milad,
Simulation for Level 2 is taking a lot of time. Its only around 9% complete in 120 mins. I expected it to be slow due to large no of cells. However, I just want to confirm. Please comment on the same.
