Solid works import
How do i import a solidworks assembley into simscale as one solid?
I et this error:
A setup with 5 regions is being used in a single-region analysis type. Please make sure that all regions except for one have an Advanced Concept assigned to them.
Hey there, and welcome to the forum!
Please always include the link to the project/geometry that is causing the error, this way we can find the issue and suggest solutions faster!
Hi, Thanks.
So just the web link?
Yes please
Hi again!
I just saw your model, and you are a little confused in how the geometry should be.
As this is a CFD analysis, you should only have the volume representing the flow region.
You can do it using our CAD Edit mode, by performing a Flow Volume Extraction - Inner Region, as outlined in this article:
Please follow the instructions to create the flow region and use it for the simulation.
