Hi @alijalil,
I’m only familiar with the sizes made in Australia. I presume that other sizes are made around the world.
I-beam dimensions are optimised to have a high strength-to-weight ratio. If you specify your own I-beam dimensions you may find that it’s performance is not optimal. For example. If the web is made too thin it may fail in buckling before it reaches it tensile capacity (as demonstrated in this video https://youtu.be/cM1mVXSFnq0)
