I want to create a simple creep test (solder), where a cylinder is loaded with a given stress over time.
I have the material properties for Garofalo-model and tried to set it under material behaviour -> creep formulation. There is no choice for Garofalo-model.
Is it possible to use Garofalo-model in Simscale or did I just overlooked the choice for Garofalo-model?
Thanks for your question and welcome to SimScale. I just took a quick look at your project; unfortunately we do not currently support the Garofalo-model.
On the basis of the power law, 3 formulations are currently available on the platform:
Hi @HannaE,
adding the Garofalo Creep Law would probably not be a lot of work to implement.
I suggest that you add a feature request in our Vote-for-features Category, to see if others would be interested as well.
