A few days ago (17th of Feb) I was following the How do I Model a Fan Curve in SimScale? tutorial by creating this project: Fan Test. The project is a box with a fan inlet and a pressure outlet. I started a simulation run (Run 1), it completed successfully and the results look correct to me.
Today (19th of Feb) I tried re-running the simulation (Run 2) and it ran for about a minute then failed with the message “An error occurred”. No Solver Log was generated.
As far as I can see, the exact same settings and mesh were used in both Run 1 and Run 2 yet one worked and the other did not.
Given the generic error message and identical settings I have no idea what I could do to troubleshoot my project. Does anyone have any ideas on what is wrong or what I can try?
Thanks.
