I have a shell and tube heat exchanger , the hot fluid flow inside a 4 turn coil and the cooling fluid is in the shell.
I made so many Iterations to my model and the same thing happens everytime, the heat exchange only takes place in the first coil.
Hey amira88,
Thanks for posting on the Forum.
Have you checked out the following tutorial yet?
It should give you a good idea of how you can setup multiple flow tracks within the same setup and seems to be what you are looking to do with your project.
Let me know if you require more support and make sure to share the URL to the relevant project! ![]()
Satvik
Hello, thank you for your reply.
Yes I checked the tutorial and I have all my setup completed and the mesh too.
However no matter what changes I do to my boundary conditions ( inlet temperature, flow rate) , still all heat exchange between the 2 fluids happens only within the first turn in the coil which doesn’t make sense
Hey @amira88 ,
Please share the specific URL to the project where you are getting the error after setting up all the right boundary conditions for us to take a closer look and provide feedback.
SimScale Dashboard - Your Simulations and Activity Overview
here is the project link, I don’t get an actual error but after running the simulation and checking the post processing information , the outcome doesn’t really make sense.
Hey @amira88,
The link does not take us to your project.
Since it has been a while, let us know if you still require support on this project. If you do, you can simply go to the part of the simulation with the issue (results in this case) and copy the URL of your browser at that time and paste it here.
