Selected point in Plot-over-Path
Can I edit the coordinates of ‘Selected points’ in ‘Plot-over-path’?
Thanks for your help.
All the best.
Hey,
Regarding the ‘Plot-over-path’ feature, the coordinates for the ‘Selected points’ are generated by manually picking points on the model’s surface. The platform currently does not support direct numerical editing of these coordinate values in the display list.
The workflow is to select (or re-select) points directly on the geometry to define or modify the path. You can find more details on this in the official documentation under the ‘Plot Over Path’ section.
Hope this helps.
Thanks. But being able to edit the entry would be great. It is not easy to pick the correct location (as one needs to handle the (multiple) cutting planes to make sure one is at the right location). So not being able to edit (or upload csv) makes it very cumbersome.
But making it ediable or csv uploadable will not happen soon, so i will use the cutting planes to guide my point’s selection.
