Residual Plots
Hey,
You have quite a lot of runs but I assume you’re talking about the wiggly aspect of your k and omega residuals? It’s tough to tell for sure.
In terms of initialization, you can use this calculator as a reference. k and omega don’t have to be spot on, they just have to be somewhere in the ballpark of the optimal value. For your sims, I’d use something along these lines:
In terms of mesh, you have good layering and y+ is looking pretty good for low AoA simulations. For higher AoA values, you should go with a full resolution approach.
It’s probably also a good idea to extend the domain at least 30 chord lengths up/downstream. Currently you have around 19 chord lengths downstream and 5 upstream.
