Problem to extract an external fluid volume in CAD mode
I’m Don. I am trying to create an external air flow simulation of a bicycle. I have designed the bicycle and the helmet in SolidWorks. The rider has been imported into SolidWorks as an STL file. I have checked the mesh several times to see if it has any inconsistencies. I am uploading my assembly via zip. In CAD mode, I want to create the fluid volume, but I cannot create it because some surfaces are incorrect.
So how can I create my simulation volume with an STL file?
Hello Don,
The issue with the .stl file is that it’s only surface and not volume-based.
What i would suggest you is to perform the subtract operation within Solidworks and upload that geometry to SimScale for meshing as a .stp file.
Another option is to use the hex-dominant mesher with the bounding box included like in this tutorial.
Best regards Sebastian
