Hi, I’m currently using the aerodynamics of car project. I completed all the works needs to be done before post processing. The simulation has been successfully completed after 3hrs. But the post-process results aren’t showing up. The page keeps loading and loading for hours, but the results aren’t visible. Please look into this issue. Thanks in advance.
sure. here’s the link : SimScale
Hi, please visit the following documentation page: Error: Connection to Server Interrupted or Result Stuck in Loading
The troubleshooting pointer #5 (resetting the solution fields to default) fixes the issue in the majority of the cases. Please let us know if it works for you.
hey hi, thanks for the reply. I have tried the above mentioned options. But the problem is still the same. “Connection to the server is interrupted”
I have checked my internet connection and its very fine. The problem is only with the mentioned aerodynamic simulation. All other simulations work fine.
Hey all,
I have also faced the same problem, I think the problem arises due to your security software and you are on a server-based network. The post-processor only work for in my case when I turned off my computer’s anti-virus software. you should turn it off and I think it will work.
In the main time, I am receiving advice from the IT department not to turn off my anti-virus so @jousefm if there is any workaround to the problem shear it here, that will be helpful.
Regards!!
hey hi, thanks for the reply. I was trying the method @Ricardopg suggested , and it worked pretty well.
I didn’t alter my anti-virus.
Sometimes, if you are accessing the post-processor from a corporate network, the antivirus/firewall may cause a problem where the results don’t load (it’s not very common but it does happen).
As you mentioned, one of the possibilities is to momentarily disable the anti-virus software. Alternatively, you can also double check with your IT department if they can whitelist SimScale’s domains (https://www.simscale.com), so it’s not filtered/blocked by your corporate network.
