GREETING ,
ACTUALLY I AM HAVING TROUBLE IN PLOTTING PMV AND PPD . CAN YOU HELP WITH THE SAME .
Hi there, this is Fillia, I hope you had a great weekend, and thank you for using the forum for the first time! Feel free to create more posts and add your insights in already existing discussions
In order to visualize the thermal comfort parameters, these need to be added in the Field calculation section under the Results Control.
Then the results will be available for visualization in the post-processing environment.
By the way, make sure to check the post-processing section of this similar project:User Guide: Thermal Comfort in a Theater Room (HVAC) | SimScale
