Hi , Would be possible to someone offer me support in my final year project from university
Kind Regards,
Welles Henrique
A description of the project and what you are trying to achieve
Full CFD Simulation best as possible with best quality images possible
An description of what is happening, screenshots or error logs are helpful
Simulation is not running
[Important] Always provide a link to your project so that it is easy to find.
https://www.simscale.com/workbench/?pid=2714065238916886978&mi=run%3A25%2Csimulation%3A11&mt=SIMULATION_RUN
Please feel free to edit the meshing or other setup parts of the project in order to achieve the best simulation outcome
It might be a good idea to ramp up the velocity at the inlet, instead of setting up the ‘full’ velocity from iteration 0 (i.e. like was done in this tutorial).
On a side note: it appears that the flow domain was extruded to the ‘wrong side’? The extension upstream from the object is much longer than the extension downstream. I’d have expected the opposite (fig 8 in the linked tutorial).
I did everything you said and even with online support from the simscale doenst seems to work , can someone edit or help me here ?
Kind Regards,
Welles Henrique
Hi there,
There are a lot of sharp edges in the geometry. It seems like your simulation fails when it reaches the airplane or so. I haven’t been able to mark all of the sharp edges but you can have a look and decide.
Perhaps you can start with removing the unnecessary sharp edges and faces. That should improve the mesh quality.
