Meshing stuck at 0%
I am doing a CFD on a car. But it seems that my meshing is stuck at 0% for 50 mins. I am using hex dominant parametric mesh.
The predicted time shown was around 48 mins before i started.
Hoping to find a solution here. Cheers!!
Link to project : https://www.simscale.com/workbench/?pid=2446195873483880936&mi=spec%3A6665f97a-828b-49a0-9f24-9ff7b8b4a468%2Cservice%3AMESHING%2Cstrategy%3A211&sh=210
Hi there, thank you for using the forum!
In contrast to the simulation, the meshing progress has discrete phases, and it is likely that it will go from 0% to an intermediate phase, and then straight to 100%. If the estimation was around 48 minutes, it is likely that it will jump from 0% to a higher value soon, In any case, make sure to check the meshing log for more information about the progress.
Thank you. It did happen the same way. By the way, it took 58 mins
