Mesh Diverges at a Certain Point
Good morning,
I’m trying to achieve a cross flow in this box using the fans in the simulation below
I keep getting this error message every time I try to run the simulation:
"Velocity field started diverging. Please check the mesh quality near the reported location and try refining the mesh. If the problem occured near a boundary, please check the boundary conditions. In case of doubt, please ask for assistance via our support chat. Velocity = 1.04284e+07 at position: (2.477 m, 0.03886 m, 0.1581 m). "
I have tried:
-Adding no slip walls but it gives me unsteady graphs
-Replacing the fan geometry, but the same error appeared
-Refining the mesh around parts of high non-orthogonality, but the same error appeared
Any advice would be super useful, as I’m still relatively new to CFD
Best Regards,
Akili Cyrus
Hello!
The usual troubleshooting steps are listed in this page - have you already trying to go through these?
Hi!
Yes, I’ve tried different mesh refinements to help it. Also I made a mistake in the title the solution diverges, but it shows the mesh is okay
Best Regards,
Akili Cyrus
A couple of hints:
  • Following the steps in the article that I linked, you will notice that there is a very small face very close to the point of divergence (have a close and careful look). Removing those faces from the turbine is a good way to proceed
  • Also, I noticed that we have a convective heat transfer simulation for this project. However I do not see any heat sinks/heat sources. If you are expecting the entire flow domain to be at 30 Celsius, I’d encourage you to use “Incompressible” instead.
