Today I was doing a simulation that I always do. But when I click to generate the mesh Simscale is sending this message:
“Currently no job instance is available for your current Community plan that matches the required capacity. Please adapt your mesh settings to reduce the overall element count and try again. Consider to upgrade to the Academic or Professional plan where this restriction doesn’t apply. Otherwise please try again in a few hours.”
I’m not understaning the reason of the message, I always do the same simulation (I did one like this four days ago). Thank you!
This error is not related to your setup, but to the available cloud servers to run the simulation.
Please wait a few hours and try to run again, it will eventually work.
Hi luisdamaso,
I had similar problems last night and also this morning, but just running a similar simulation that was previously working and it seems to be processing now.
Regards
Ted
Hi TedBurke! Thank you for message, I was afraid to be an error with my account. I tried to generate the mesh a couple of minutes ago and now is processing.
Have a good night!
Now the mesh is generating. Thank you for the message!
