- A problem during the material model integration occurred. Try using a linear elastic material to rule out any issues with the boundary condition setup. If the run succeeds with a linear material, verify your nonlinear material settings, refine the time stepping and check the mesh quality.
Perhaps, this documentation page will be helpful in resolving the issue
Hey @saicad ,
Did you already take a look at the documentation mentioned by @nelta ?
If you also tried the following as the error message stated:
- Using a linear elastic material
- Verifying non-linear material properties
- Refining the time step
- Checking the mesh quality
please share the project URL where it still does not work. Remember to also share the project with support so we can take a closer look.
Satvik
