Greetings,
Incompressible flow model 1 input and 7 outputs. I am not seeing all outputs after the simulation run. Any insight would be greatly appreciated. What is the difference between velocity inlet and Pressure Inlet?
Public Project:
I only see flow in 1 outlet anyway to see all outlets?
Many Thanks
Rob
Hi @rlierman, thanks for posting at our forum
I’m taking a look at your project and get back to you later with my findings.
Hi @rlierman,
I guess what you’re looking for is the view in the parts color:
However, you can also set it as a solid color and apply multiple cutting planes as well (don’t forget do disable the clip model option):
An useful guide on post-processing within the platform can be found here:
Does that help?
Igor, Worked Many Thanks.
