I have read the doc of the CAD Mode:
but do not find a method to partition a solid. By partitioning I mean to cut the solid with a surface or plane, getting then 2 “subsolids”. Example: a rectangular box partitioned with a plane which is parallel to one of the box surfaces would have then 2 subsolids. The whole body (which can be named “compound”) would then possess 11 faces (and not 2*6=12 faces, 6 of each subsolid). They are 11 faces because in the cut plane there is only 1 surface, i.e. the 2 subsolids share this surface.
Having more than 1 subsolid is essential to assign more then 1 material. I have only found the split method in CAD Mode. 2 materials can be assigned then as well, but a bonded contact (glue contact) is additional necessary in order to glue the solids together which do (after split) NOT share the same surface of the interface.
So, did I oversee a method for partitioning?
thank you and regards
Johannes_ACKVA
www.code-aster.de
