High value of coefficient of lift and drag
Hi there, thank you for reaching out to us!
This is a common question of many users, and my first comment is to always keep in mind that 3D and 2D are expected to have different results.
In order to get as reliable results as possible with your 3D model, make sure to create a good mesh.
For example, I see you are using a reference area of 1 m² in your Results Control set up, which does not seem to be the correct value.
