hi, I was wondering about what write interval in forces and moments does. should It be changed, should it stay the same?
thank you for your time and help,
frank
lucci
Hi Frank,
With the Write interval input you specify the frequency with which the simulation results will be written. If it is set to 100 for example, the results will be written every 100 loops.
You can check the simulation control settings here: Simulation Control for Fluid Analysis | Documentation | SimScale
