Hello
I am lloking for example how to set a force normal to hole.
Like Tutorial 1 but force instead of pressure.
Hi there, could you add the link to the tutorial you are referring to, and also a screenshot showing the boundary condition you mentioned? (the pressure one)
Hi, there should be an example in the voluminal load validation case, more specifically figure 4 and the information box under figure 4.
Basically you would need to convert cartesian coordinates into cylindrical coordinates to ensure that the forces are normal. Of course, using a pressure is more straightforward, since it will always be normal to the face.
