Hello there,
Thanks to your support, I am happily running my structures for fluid analysis.
The complexity of my structure is increased, I need to see the aerodynamic fluid flow through pipe which has the installed filters inside.
As I have expected, I have seen the warnings of the platform, which require me to close the gaps. I understand that inner fluid region can’t be made with the pipe with cavity region, but the small opening of the pipe is actually not intentional. (In other words, the upper and lower openings should be closed). My question is,
How can I close the openings of my structure? (It was hard from my side to close the gaps with “close sheet” function)
If the openings are closed, what else should I do to make internal fluid flow volume with the filters inside the pipe?
(I expect so many warnings with the structures inside) please let me know if there is document to refer to treat this structure.
*The attached pic shows error situation, and another picture shows the red arrow for air fluid flow direction inside the pipe.
Thanks always!
Best, Kim
