External aerodynamic forces on a rear wing of a Formula 1 car
Velocity started diverging, Please check the mesh quality near the reported location and try refining the mesh. If the problem occurred near a boundary, please check the boundary conditions. In case of doubt, please ask for assistance via our support chat. Velocity = (1.411m,-0.002854m,6.339m)
It seems you have deleted the simulation run that diverged, so I can not possible check what went wrong. This is probably a mesh issue, some bad cells create high values, and then the simulation fails. Unfortunately without the run I can’t locate these cells, so you will have to use the probe point to understand which area is problematic and needs refinement. Use these guides when divergence occurs:
